06.13.2007, 07:09 PM
The fluid will depend on how you want the truck to perform.
The only problem with the truggy diffs is the lower gear ratio. However, if you can make it up in spur/pinion gearing or increasing tire size, it won't matter. It's the final rollout value that is made up of all the gearing and tire diameter.
