lydiasdad
06.14.2007, 11:30 AM
A123's have their pro's and con's when compared to li-po packs. The biggest pro is durability. They can be charged at up to 10 amps and you don't need a lvc to protect from over discharge. Their capacity is only 2300mah per cell though. Good li-po cells can put out more power with less weight. A123 cells can be more diffuclt to mount also although that varys from vehicle to vehicle. I went from gp 3300's to these A123 cells and I am very happy with them.
jimbob
06.14.2007, 11:42 AM
sounds interesting, but ya i saw they only make 2300 cells, but you can paralell them right?
i might look into them also, i saw somewhere that they have 60A bursts ?? but if your running them with a 820 motor and ther not getting hot then it sounds good
what kinda charger do you need as they are 3.3V a cell aren;t they :eek:
