ya i would stick with the 550's then, you could always get a 35-75 turn motor but they are really slow but will work on 7.2V.. dunno how much room you got for two packs on the blackfoot
get some pics up, im sure we all want to see :018: i am thinking that it must look pretty good
Pics are coming in about an hour. I'm getting ready to leave work. Any idea if the twin Det front gear box assembly would fit in the Blackfoot extreme? I have a 14.4V ESC from an E-maxx so II could run twin motors.
All electronics has a motor that is even longer than a 550. It is as long as a 750 sized motor but is the diameter of a normal 540/550 motor. It can also handle up to 24 volts. It has the torque to turn those big tires. http://www.allelectronics.com/cgi-bi...3-24_VDC_.html
