zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.17.2007, 01:31 AM
There will be a green wire in the main ATX mobo power connector (20+ pins), all you have to do it make an on/off switch in between that and ground, which is the case of the PSU unit, or you can just direct connect it and use the rear switch to turn on, but the first option is recommended, IMO.
Then if you want more voltage, SOME psu's have calibrating pot's on them, so they can be adjusted to put out higher voltage than 12 volts.
Quite simple really. :)
