wat is a UBEC/BEC?
damaxxman
wat is a UBEC/BEC? - 06.17.2007, 10:47 AM
i'm putting a 9xl with a MM esc, and goin to be running 14-16 cells, i was on here before and they said i should use a ubec. I dont know wat this is. O and when wiring up my batteries should i put them in a series or a parallel curcuit?
06.17.2007, 11:10 AM
Welcome to the forums!
This page should help you out.
damaxxman
06.17.2007, 11:21 AM
so if im runnin 14-16 cells with my 9xl do i run a series or parallel for my batteries?
Sean
AKA Monkey
06.17.2007, 11:27 AM
series increases the volts (speed) and parallel increases the battery capacity (run time) im guessiing you will want them in series for the extra volts
Cars:
Kyosho Lazer ZX-5, 74MPH Pictures
E-hyper-7 Pro UK
EB4 s3, STS28
My Cars and Projects
  Send a message via MSN to Sean
damaxxman
06.17.2007, 11:44 AM
ok so if i run my 16 cells in a series wat do u think ill get for top speed? and my motor can handle this?
Sean
AKA Monkey
06.17.2007, 12:01 PM
probably about 45 mph at a guess and yes your motor can handle it but the controller is only rated up to 12 cells all tohug i have heard of people runing them on more.
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
damaxxman
06.17.2007, 12:07 PM
i am runnin it with a ubec.
bdebde
That's All Folks!
bdebde's Avatar
06.17.2007, 01:18 PM
4s (16.8v full charge) with the UBEC is no problem for the MM, I have one set up that way. 16 cells would be a bit more initial voltage, but some have had good luck up to 5s (21v full charge) with the MM.
