AAngel
06.19.2007, 01:53 AM
Yes, I do like to keep things conservative, so you have to take what I say with a grain of salt. I'm way down south, so I have 100*F ambient temps to contend with too and there's lots of humidity which just makes everything worse.
If going fast is what you want, you might also want to consider a 7XL. I know that many who run in cooler climates have no problems running the hot motor. I have two of them and they do get a truck moving.
Finnster
KillaHurtz
Finnster's Avatar
06.19.2007, 10:22 AM
i ran 16 cells a bit last year b4 I went lipo. Higher init voltage (23+V, caps rated to 25V) but 4S gives better performance IMO. The top speed on 16 cells is a bit higher, but punch and accel is better w/ lipo. Plus a lot less weight. 5S is way more power than 16cells.
4S/14cells and 8Xl is a great combo for reasonable speed and reliability. If you can go to 14cells, that would be the biggest help. Better cells at that too. The 3600s might be ok, but I can tell you the 3000s are crap. :)
