06.19.2007, 05:41 PM
You dont get much chassis for your money do you?! But I think thats the whole idea. The emaxx tranny should bolt in fine, but you will definately have to buy/build some proper battery trays for it. Those diffs are very weird, but being UE with 1/8 gears should make them indestructable with the HvMaxx- just be aware that on 14.4v you will want a gear ratio of between 25-30:1 overall, depending on weight, but that should be a pretty light truck when its finished~ 9-11lbs maybe.
Is that your GF in your avatar- I can see why you would want to spend alot of time with her.....
