Happywing
06.21.2007, 02:44 PM
The cogging (push-start) problem seems to be common with the MM combined with a Novak or LRP BL motor. Better batteries should help.
jhautz
jhautz's Avatar
06.21.2007, 02:49 PM
Better batteries will help that start up problem. Get a decent set of at least GP3300 or IB3800 and you should see a big improvement on the start up. Try playing with the timing settingon the MM that might help also.
to make it...
or break it...
Silent...But Deadly
sven
sven's Avatar
06.21.2007, 08:07 PM
I tried all of the timing settings and they all performed the same.
Even though it's a push start vehicle, I'm still having a ton of fun with it because it's the fastest vehicle I've had in 2 years. The crawlers top out around 4 mph :027: .
Here's some video...kinda sucks cause I need a camera man.
kufman
06.23.2007, 02:45 PM
Do you have the stock rotor in the novak motor? I put my feigao rotor in my ss5800 can and it worked much better. I would venture a guess that the novak sintered rotor upgrade will help too. I run my novak motor off of a u-force 75 and the startup sounded just like yours before I switched the rotor.
nazspeed
06.23.2007, 05:08 PM
check and make sure nothing is biding either sometimes its the small things you dont see that cause the problem!
