crazyjr
crazyjr's Avatar
06.21.2007, 04:29 PM
I was doing some checking and the motor will not fit without an adapter, so the 1/10 setup is off. But, I found out the motor will line up in 380 mounts, so it will still have a home in my mini quake. I had a 1020/11turn in it and it was not a good setup, seemed to not like pulling the mini quake with a 5400kv, but the Neu has a 3400kv, which is almost perfect for MINI MT. there is a slight shift in the plans but it will give me a chance to see if the mamba 25 can do Neu;)
