sven
sven's Avatar
06.21.2007, 08:07 PM
I tried all of the timing settings and they all performed the same.
Even though it's a push start vehicle, I'm still having a ton of fun with it because it's the fastest vehicle I've had in 2 years. The crawlers top out around 4 mph :027: .
Here's some video...kinda sucks cause I need a camera man.
kufman
06.23.2007, 02:45 PM
Do you have the stock rotor in the novak motor? I put my feigao rotor in my ss5800 can and it worked much better. I would venture a guess that the novak sintered rotor upgrade will help too. I run my novak motor off of a u-force 75 and the startup sounded just like yours before I switched the rotor.
nazspeed
06.23.2007, 05:08 PM
check and make sure nothing is biding either sometimes its the small things you dont see that cause the problem!
