Not that I know of. You might be able to modify it, but will be toough as they are made of hardened steel most of the time. I would just get the appropriate pinion.
Unfortunately, there is no appropriate pinion. I think I can make it work with an airplane prop adapter. A little bit ugly, but it has worked in the past.
