yep
yep - 06.25.2007, 02:34 PM
i bought it as a system, ran two charges and snapped a rotor, got it back ran 1/2 a charge in a rustler and got it wet, got a faulty replacement sent to me for a 1/4 charge, as it sits right now i've got over $400 into a novak setup with less than 4 charges through it, right now i'm waiting for an inverted motor mount from kershaw designs because i put the diffs in backwards and don't want to tear down my truck
ElectricThunder
06.25.2007, 04:47 PM
If you purchased an HV 6.5 system, then it already has the sintered rotor. If you got the HV4400, then it doesn't have a sintered rotor. Voila!
crazyjr
crazyjr's Avatar
06.25.2007, 08:17 PM
All you need to do is turn the tranny backwards, but it will eliminate the shift selector
