neweuser
neweuser's Avatar
08.24.2007, 04:08 PM
Hmmm, I had 6000's and they seemed enough to push my 10xl....just lacked the run time.
But Serum is right, I would contact Austin, who is a great guy.
crazyjr
crazyjr's Avatar
08.24.2007, 06:10 PM
Another thing to consider, the HV4400 was lower powered, so it needs current to run hard, thats going to play havoc with all but the best LIPO's. I run NIMH on mine (12 cells) and they would come off so hot i would not be able to charge them for at least an hour, because they needed that much time to cool down
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.24.2007, 06:19 PM
It could also be poor solder joints as well? Have you checked all solder points for quality bond? Lengthy wires might be the culprit too, who knows?
Lipo
Klausen
Brushless G-maxx
Klausen's Avatar
Lipo - 08.25.2007, 02:21 AM
Hi again
Thanks for all the replys.
I know I should have got the 8000mah. in the first place, but I am still not sure that it is the problem. When I take of the lisaver, there is no problems at all. It just flies away, with no "cogging".
When I am finished driving the lipos are hardly warm, but the motor is for sure.
Could this be a motor issue. Would it help me to replace the rotor with the HV 6,5 rotor (the cheap solution), or should I upgrade to a senserless system?
Best regards
Jesper
