08.27.2007, 03:39 PM
Hmm. I'm not sure if those would be adequate. I use them on my Jato and CRT.5 and they work fine, but those are much smaller and lighter vehicles. I would see what someone else says about them.
If you go to 6s on a Neu 1512/3d (kv=1700), the 5,000mAh cells should be ok since the higher wind will pull less current. For that setup, I'd use a 12T or 13T pinion on the 46T spur. This should keep you in the 35mph top speed range.
