kulangflow
Never Fast Enough
kulangflow's Avatar
09.02.2007, 06:07 PM
Originally Posted by Patrick View Post
To do that you'll need 1 female plug and two male plugs (assuming your using a plug with both wires in the same plug eg. deans, tamiya, powerpoles etc)
For the record, you don't need to make an adapter to do series with powerpoles. That's actually the primary reason I use them.
+ and - are genderless, so you can just plug the + on one pack into the - on the other. (This, of course, is a very dangerous characteristic if you're not careful.)
Good times.
