MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.04.2007, 12:26 AM
Google has failed me on the cf stuff. It brings up complete rubbish. Maybe I don't know what to search for. It is a shame graphite elegance seems to have given up. I'll check McMastercarr.com out.
On the motors I would love to get a Neu 1515 but I don't think the funds are going to stretch that far. I was going to heat sink the motor as I knew it would run a bit hot. The quark seems to have a reputation for running hot. what other esc are similarly spec'ed. I won't be too upset if I burn a motor but to have an esc die at $250 each I'll do more then cry.
Also any one recommend a fan? I know people use pc fans but the ones I can get would be far too big.
Edit: I worked out why google is failing me. bloody Americans and their crazy spelling. What's 'fiber'.
jnev
jnev's Avatar
09.04.2007, 01:36 AM
lol, thats funny. =)
As for another ESC, the MGM Compro 160 has been running very cool for people with it, and it can actually run 6s successfully if you ever want to unlike the Quark. There is also computer programming for it, so that makes it even easier. same price as the quark as well.
Keep us updated with pictures of the Savage. BTW - who is making your motor mount or where are you getting it from?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.04.2007, 04:37 AM
Does the MGM Compro 160 support 4 pole motors (a neu 1515 may come one day)? Did I read it right. Does this not need a separate bec even when running 6s?
As far as motor mount goes I was going to get the Kershaw Designs one but I wanted one that mounts the engine lower for a better cg and to keep the motor out of harms way. I discovered that one of the guys at work has access to a workshop and can make me the mount. I just need to draw one up. Does anyone have a low mounting engine plate design in cad that I could possible use? I know it's a big ask as I would be copying someone else's hard work but I though I would ask.
And as far as keeping you guys posted I definitely will. As soon as I get all the bits I have ordered so I can at least put the savage back together I will post pics and weigh it so I can use the calculators that are setup on this site. This forum has been a massive help so far. I was really struggling to find any info on converting savages and the different options until I found this forum.
Edit: and as far as the CF battery mounts go I will probably go aluminium U channel. The CF is too expensive.
Etid2: To answer an earlier point to, I don't feel like destroying my savage tranny too much. I may eventually get an LST2 and move the BL setup to that and make the savage a nitro again. I think the LST2 is a better platform for a brushless setup just because the battery mounting is so much simpler. Plus it would be nice to have to monster trucks in case one breaks.
jnev
jnev's Avatar
09.04.2007, 08:14 PM
Yes
That is correct.
Good luck with the project.
