BlackedOutREVO
09.04.2007, 05:54 PM
Originally Posted by captain harlock View Post
My! If I read Mike's thread properly, I wouldn't have to ask about the servo, lol!
What about the body, though?
You use a jato body
BP and Cem are using the CP for the jato
And yeah, I wouldnt even want to run a mini servo, Just go for the big ones
jhautz
jhautz's Avatar
09.04.2007, 09:21 PM
Just wondering if the extended chassis has center dif mount screw hole locations that allow for the plastic spur to fit on the diff. From what I understand the spur fits the diff but makes the dif just a little bit too long. So moving one set of mounting holes a mm or 2 would allow the use of the plastic spur on the center diff. Just woundering if that feature was added to the new chassis. Seems like it would be easy to do.
to make it...
or break it...
Silent...But Deadly
cemetery gates
09.04.2007, 10:23 PM
Nope, it wasn't. You are the first person who I think actually thought of this. You would need a new bearing for the new spur, new diff mount(mike would have to change his motor mount to fit the new bearing) and a new diff outdrive. There maybe more I am forgetting though so, its not so easy really. Besides, with the new hardened pinions you have no trouble at all with wear on the metal spur. It is stronger than a plastic spur and more reliable IMO. I have had almost 40+ runs on it and no sighs of wear.
I have a 4s 4200mAh lipo on the way for the crt.5(with 10L motor), so things should get interesting now ;).....
Bye:)
