mkrusedc
NeuMaxx
mkrusedc's Avatar
09.06.2007, 08:17 AM
This is the problem I just ran into. My MM is around 3 years old and can't run 14 cells at 16.8 volts. Isn't a 5s 18.5 volts?
Finnster
KillaHurtz
Finnster's Avatar
09.06.2007, 09:19 AM
How do you have a 3yo MM when they came out a year ago ? lol.
14 cells will peak at ~20V, 5S 21V.
If they built over volt protection into the new escs I'm going to be really disappointed...
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.06.2007, 09:27 AM
The Mamba Max last year? I bought a MM esc with A 7700kv motor as a set from my lhs almost a year before hurricane Katrina, which makes it 3 years ago.
Edit: The owner told me that one of his former employees works at Castle. Did I get some kind of deal and didn't know it?
GriffinRU
09.06.2007, 10:09 AM
I have 2 generations of MambaMax (different FET's) and so far have not seen any limits.
But with time capacitors are loosing their properties making ESC more sensitive to voltage spikes.
And knowing that MambaMax capacitors are not rated for bigger motors, makes perfect sense that some ESC more or less sensitive to higher voltage due to the variation in capacitors parameters from batch to batch...
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.06.2007, 10:24 AM
GriffinRu,
Mine is about 3 years old and I have thermalled it 3 times. Would your mod help or I should get a Quark or an MGM?
squeeforever
squeeforever's Avatar
09.06.2007, 04:39 PM
GriffinRu,
I don't see how its 3 years old. They've only been out for about a year and a half, or slightly less, and the beta testers didn't even get them until the came out to the public...
mkrusedc
NeuMaxx
mkrusedc's Avatar
Red face 09.06.2007, 09:59 PM
Maybe my brain is getting fried in my old age. Either that or everything is a blur ,since hurricane Katrina, but you all are right I got it in December of 2006 according to my receipt.
GriffinRU
09.06.2007, 05:48 PM
I will get new MambaMax and check it for any voltage monitoring features. It would be sad if CC do such a thing...
GriffinRu,
You can follow my steps and do the mod yourself as result you will get better heatsinking for ESC and less chance to thermal it.
As far 5S support, I would like to get ESC which hesitate to work right away, maybe there is something else, I've seen many time low voltage cutoff set to wrong value and this will do the blinking.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.06.2007, 06:16 PM
I set it low and high and even tried it with the LVC disabled. Still no go.
