It's not about the pin coolhand, it is about the other side of the cup.. ;)
Just use a very good key to lock it and some loctite and you will be fine! can't you use some other pin that goes thru? i don't know what the diameter of the hole is and what thread size it has..? i have got two different pins with the screw connected to it from my savage, i would like to measure them for you?
