MetalMan
MetalMan's Avatar
09.08.2007, 12:26 AM
The older MGMs (like from a year ago) had a cutoff of about 3.2v, that I found from my testing. If my memory serves correctly, I found this by using my ICE set to motor break-in mode (essentially a variable-voltage power supply), and set the cutoff to hard cutoff on 2s Lipo. Then I decreased the voltage until the MGM cut the motor, at which point I was at 6.4v.
