09.15.2007, 05:20 PM
Basically, I just need the info requested in that thread. With all the data, I want to do the following:
- Calculate estimated burst current based on reported runtime on specific battery type/size, truck type, top speed (which auto factors gearing, tranny, tire size), and weight. 6x-7x average amperage multiplier seems to be pretty good for a ball park figure, but I'm sure it will vary depending on the above factors.
- Calculate mimumum lipo specs (mostly C rating) based on the estimated burst current so people can choose a lipo setup that won't be overloaded.
- I'll probably also throw together a section (or even a seperate page) where the user can enter their current runtime and battery specs, then enter desired runtime, and the script will calculate the needed battery.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.15.2007, 05:35 PM
That sounds like a great addition to it Brian! Just what ppl need!
This run was done in thick grass, and it looks like this pack can deliver 1550 watts! It's not in the snapshot I am posting but later on in the data graph.
I will post this here, and on the other thread, kk?
I can sure feel the decrease in punch though, going from 2p to 1p pack, but it's still pretty good feel of power as I can wheelie at speeds up to roughly 32mph, of the ~<40mph top speed.
Name:	Eagletree 7s1p pack 13T (2).jpg
zeropointbug
Z-Pinch racer
09.15.2007, 05:49 PM
Also, I checked out the cumulative mah of the recorded run, it shows up as 2500mah! Every A123 pack I have had has always been quite a bit over th rated cap, which I'm not complaining about!
The max amps was 85 amps too, maybe I will post another one with amps instead of watts?
