dadnjesse
09.09.2007, 09:51 PM
Something that was throwing me off was on page 6 on the graph down the bottom of the page, parameter B, it has two lines, the top line is light 1 and undernieth is 0.13 sec then light 2 with 0.26 sec undernieth. That is one line not two. And if you're not carefull you could mistake that as two lines, which will screw up the rest.
my MGM 12018
gyn77
my MGM 12018 - 09.10.2007, 06:41 AM
I had bad luck too with MGM.
I bought a 12018 cube version on June to run with 6s lipo with a feigao 9XL.
When arrived me, I connected 6s lipo, the esc made smoke soon.
So I sent my ESC back to MGM and they repairred in warranty my esc.
When the esc came back me, I did not succeed to make it work because I did not understand how to program it.
After many tests on yesterday, I understood this to program the esc:
1) turn on receiver while stick is at max backward (not at forward how tell the manual)
2) after 10 seconds the esc and the motor beeps x 3
3) stick at full forward, 1 beep
4) stick at full backward, 3 beeps
5) stick at neutral, 2 beeps
6) turn off
In this way, I have run with MGM at 2s, the same at 4s, but when I connected 6s lipo, at the first accelerated the Esc went in fire.
On this morning I sent again my ESC back to MGM...
