JPP
09.10.2007, 01:12 PM
Since I've been trying to program over and over again, I actually wound up writing out clearer instructions (similar to what jhautz just did) in Word. It reduced the stress level significantly (although not as much as if I had been able to program successfully!). That said, I've never had to do that with my Castle, Novak, or Quark controllers!
Incidentally, one other thing I noticed is that to get mine to recognize full throttle, full brake, and neutral, I have to set the throttle subtrim to somewhere between 15 and 25 (where, exactly, seems to be random, depending on the time I turn it on), and the EPA on brake to 10 (out of 100). I am able to leave the throttle EPA at 100. I'm running a Nomadio React, have 4 other vehicles on the same radio and have never had a similar problem. Is this normal?
JPP
lutach
lutach's Avatar
09.10.2007, 03:38 PM
JPP
Your radio might be the one to blame. I just programmed my MGM with a JR and a Spektrum and the controller worked the same as it did with my Airtronics.
JPP
09.10.2007, 03:42 PM
I thought of that. For kicks, I tried using the Duratrax radio that came with my Vendetta, with similar results.
lutach
lutach's Avatar
09.10.2007, 03:44 PM
I thought my 8012 was a gonner when it did that, but just by doing the programming it was fixed. Did you try reprogramming the controller with the duratrax radio?
JPP
09.10.2007, 03:45 PM
I thought I had but I'll try again tonight.
Delboy
11.14.2007, 07:07 AM
JPP
JPP did you ever resolve the throttle mid point problem? I have a similar issue where I need the midpoint to be recognised as OFF/Idle but the MGM will not program unless i use the full throttle/brake travel. This results in the mid point being half throttle and no brakes?
JPP
11.14.2007, 09:33 AM
Unfortunately I had to put everything RC away for the past 2 months due to my wedding/honeymoon and home renovations. Probably won't be able to break the stuff out again for another month or so, by which time Tekin should be close to rolling out their R1MT and Castle their MMM. Or I may just switch to a MM with a UBEC and fans, since I'm just using 4s.
Incidentally, what radio are you using? Is it a Nomadio product?
david lamontagn
11.14.2007, 04:13 PM
STOOOOOOOPPPPPPPPPP your horror history of MGM controler
I'll suppose to recieve my 16018 tomorrow of friday, with the programing device, and i'am reading your smoking history with brend new MGM!!!!
I'll be very nervous to plug the batterie on mine.......
What happen with this $250.00++ controler??????
ope to not have any issue with mine.
Began to have somes regrets to not have take a Quark......
JPP
11.14.2007, 04:38 PM
I understand the Quark has its own issues around cooling. As to the MGM, mine was repaired under warranty (although it took 6 weeks to get it back), and I view what happened as an aberration. The big problem as far as I'm concerned is the programming issue; I'm not the only one who has had issues with that.
Let us know how it goes.
david lamontagn
11.14.2007, 08:01 PM
Why did you keep to use the Tx programming method
The USB COM is suppose to simplify the programming task alot.
And for the price of this little programing device, don't know why lot of people keep to use the Tx for programming this controler.
JPP
11.14.2007, 08:20 PM
I've since ordered the USBcom+ and will try it when I next get the chance, although I'm in essence having a problem simply pairing the device with my Tx. On a fundamental level, you have to get the ESC to recognize the end points of the Tx, no?
MGM 16016 RB car setup solved.
Delboy
MGM 16016 RB car setup solved. - 11.14.2007, 11:16 PM
On this setup we are using the stock Losi radio, I run the React on my E-LST2 which has a Hydra 120 ESC.
Finally sorted the issue. The TMM16016 is a Z-Series 'RB' ESC (Race Boat) which is not actually what I ordered. Key difference is that it only has Forward (no reverse or brake) which is fine for the LST2 so it expects different end/mid points. By offsetting the Throttle on the TX I can program it as documented and it behaves fine.
I did order the USB (and may order the Black box as well) but it is out of stock here in Australia so am stuck with the 'hit and miss' TX programming at present.
Main concern is that I have the Lipo 4S setup correctly, if I read the instructions correctly I think the ESC still does a check on the number of cells connected and fails to start if there is a mismatch?
PS There is no BEC on this model which is also OK as we continue to use the RX Battery anyway as most of the ESC's we have access too do not support 4S for the BEC, this also keeps the ESC temperature down so we will continue to use the RX Battery.
david lamontagn
11.14.2007, 11:32 PM
Tell me something, at the first time that we use the controler, how the controler will know the number of li-po cells connect to him????
They need power to turn on, and we don't have the choice to plug any batt to the controler to fire up and can go into the programation to setup the parameters...
So at the first time you use the controler, if he don't recognise the number of cell and fails to start, how can we program it????
Delboy
11.15.2007, 01:59 AM
The ESC can approximate the number of cells based on the voltage. I guess initally it checks the voltage, sets itself up accordingly so you can program it. Once it knows whether you are using NiMh or Lipo it can work out the number of cells fairly easily.
Just my guess........
Finnster
KillaHurtz
Finnster's Avatar
11.15.2007, 11:53 AM
The controller defaults to Nimh mode, so there is no voltage cutoff.
Are we sure that the controller won't even turn on if there is low voltage, or just not arm? If you messed up the cell count, ie put 6 instead of 4, don't have a 6cell lipo, it doesn't seem right that this would just brick the esc until you could get a HV pack. I could see it let you do the programming, but not arm, but haven't tried it so don't know for sure.
