Nice - I've been wanting to do a motor mount at the rear of my Neu in a similar fashion as yours. Something that would hold the rear of the can at a fixed height to avoid movement and also transfer heat to the chassis. I wish I had a machine shop.
Yes i descide redesign motor holders, read lots of problems with popping out front/back so i descide avoid it solve problem bit differently.
Holders was made from 8mm Al and cut on water cutting machine, whats why those details not shine like on CNC.
BrianG you right this is exact ESC what spoke on ESC hacking thread. ESC works very well, i mean its not heating up at all and have pretty good start no cogging at all. And yes I am using Pistix to control it with pistol type radio.
Only bad thing what its not so sensitive to trigger movement. But if motor started and works about 2sek and you will press full trottle it spin up motor instantly. But once you release it and again to full it spin motor up with stupid delay its about 0,5sek but its enough to feel it. I think this feature made to save plane motor gearboxes.
Exept this the chinese ESC quality is realy good for $65! I wish what they will make CAR ESC with same spec's
BTW i mailed to them with that question do they plan to do something becouse here is lot of potential customers. Only few brands have HV ESC for car.
...BrianG you right this is exact ESC what spoke on ESC hacking thread. ESC works very well, i mean its not heating up at all and have pretty good start no cogging at all. And yes I am using Pistix to control it with pistol type radio.
Only bad thing what its not so sensitive to trigger movement. But if motor started and works about 2sek and you will press full trottle it spin up motor instantly. But once you release it and again to full it spin motor up with stupid delay its about 0,5sek but its enough to feel it. I think this feature made to save plane motor gearboxes...
So, do you think that the "delay" is from the pistix module or truly from the ESC?
I'm working on a HV controller for us car guys LOL.
I wish I could say the price would be that, but a software for car use is much more complex that for the aircraft controller. I'm still waiting for an answer from the engineer to see if he will send me a 100A 10S lipo controller with the car software.
