09.14.2007, 09:44 AM
An ESCs throttle input is pretty simple really: it expects a minimum "on" signal of 1ms pulses and a maximum "on" signal of 2ms pulses (50-60Hz frequency). It just depends what your radio puts out.
A wheel radio is set up for 1ms - 1.5ms - 2ms pulses for reverse/brake - neutral - full throttle, respectively.
An air radio is set up for 1ms - 2ms pulses for neutral - full throttle respectively.
Depending on the radio you get, you may be able to emulate both these modes by setting the EPA. But if you have an inexpensive wheel that is not sufficiently adjustable, the pistix module does it for you on the receiver end.
09.14.2007, 10:13 AM
Thanks Brian. Not sure if I told you, but I ran your 2s2p emoli packs in series on my 7xl buggy and it ran well, the batteries only heated up when I tried to get that last 30 secs of runtime when the lvc started kicking in. Do you think the lvc shold be set a little higher than 3v/cell with the emoli? Maybe 3.2v/cell?
