rchippie
rchippie's Avatar
09.14.2007, 12:26 PM
The best way is to combine high-speed heatsinking (Copper) and low-speed (Alum), then ceramic can be utilized as long as it is very thin. And I think that is the idea behind all packages.
So when we mod the quark are we better off using a copper or aluminum heat spreader ?. And would it better to have a heat sink made from copper also ?. Thank's
REAL MEN RUN BRUSHLESS
GriffinRU
09.14.2007, 12:33 PM
I am working with Mike on Brass-Copper heatsink for Quark, updates will come pretty soon :)
Originally Posted by lutach
Do you think that guy is for real with his true 150A continuous controller? What he basically said is that my controller is a 95A controller. I'll just have to wait and put out the numbers.
I haven't seen nor touched his controller, so I do not know yet.
I thought we did the estimate with you before.
rchippie
rchippie's Avatar
09.14.2007, 12:39 PM
Thank's artur for the heatsink update. Whats your opinion on the heat spreader for the quark, copper or aluminum ?. Artur how have you been ?.
GriffinRU
09.14.2007, 12:55 PM
You welcome!
For Quark:
- use stock alum housing as external heatsink
- replace both alum internal plates with brass
Challenge:
- very tight inside
- galvanics, is it a problem? :)
- soldering...
lutach
lutach's Avatar
09.17.2007, 10:36 AM
I just heard from the engineer and he is having some trouble with the software. This is what he asked me: "We need to know when the brake apply. For example, to what exactly position you turn the trigger will just free the motor and to what position you turn the trigger will apply the brake." I told him that the brake has to be proportional with the trigger and it should not be applied when the throttle is at neutral. I know there is the "ms" things and I have no clue what they mean and if they could help them at all. Any inputs will be appreciated.
MetalMan
MetalMan's Avatar
09.17.2007, 01:06 PM
My guess for "ms" is milliseconds. The transmitter sends out throttle pulses of 0-2ms long, depending upon the position of the trigger. 1ms is neutral. For airplane radios, I believe 0ms is neutral (since they don't have reverse).
