lutach
lutach's Avatar
09.14.2007, 08:29 PM
In the following pictures I have the XL next to a 88mm long motor and that 88mm long motor next to the 1521.
Name:	8XL and 3688.jpg
ID:	3240   Click image for larger version
09.14.2007, 08:40 PM
Neu 1521 is 3.3"/83.82mm long, the XL motors are 2.91"/74mm.
nl12
nl12's Avatar
09.14.2007, 09:40 PM
Dude 10s is crazy I had a 8s setup in a Jammin CRT and it was very hard on the diffs my rear ring gears lasted 5-6 charges. I would try Xray diffs I hear they are the best. If you run 10s and make your truck as light as you can. I would suggest 2 5s 4500 30c flightpowers. I have more fun with 5s or 6s setups than I did with my 8s setup it was an expensive lesson to learn. Good luck.
Nick
COOKIES!
Nick's Avatar
09.15.2007, 05:01 AM
Thanks nl12, that's good advice, I'll definatly consider it as I've gone down the wrong road many times before!
I run 8 Spyder Diffs, do you think they'll be okay? Are the Xrays better than this?
~ Nick.
pcnutz
pcnutz's Avatar
09.16.2007, 11:05 PM
nothing beats the kyosho real harden steel diffs, especialy the tcd up front
