nativepaul
nativepaul's Avatar
09.16.2007, 12:27 PM
The problem with PlastiDip is that it makes repairs very difficult should anything go wrong, you can just cut the shrink off in seconds the way I do it, or conformal coating will just burn off when you solder through it, but removing a thick plastic coating is tricky and its hard to see whats gone wrong in the first place.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
speedy
09.17.2007, 12:21 PM
Hi !
I'd like to use my mambamax esc so i need a good motor/gearing setup for this truck can you gut's help me out `:) o and does mike's engine mount for kyosho buggys fit the st ? I also need to know how much amp's this motor will need to preform ! so i know how big lipopack i need :)
