dadnjesse
09.18.2007, 10:29 PM
I ended up using 10k up front, 50k center and 3k in the rear
A4DTM
09.19.2007, 09:45 PM
how do you like it? i've still got stock in front and rear, but my rear needs rebuilding.. do you know what stock oils it had? and how does it compare now?
Sower
Sower's Avatar
09.20.2007, 03:15 PM
My CRT has 7k in the front, 30k in the center, and 3k in the rear. Works awesome for me. Although I can still pull the front tires off the ground on the straight away, so maybe I need to thin the front a little?
waterdog49
Team F.U.B.A.R. Racing
09.20.2007, 04:49 PM
i run 7F/30C/5R in my Losi 8T with Neu 1515 1Y/F on 4s lipo...
Ron
time trials videos...
http://www.rcboatingdistributors.com/SAWVideo.htm
electric truggy conversion pictures...
http://skellyo.com/Ron/
bdebde
That's All Folks!
bdebde's Avatar
09.21.2007, 10:43 AM
Yah need to thin the center if you're pulling the front end up.
Sower
Sower's Avatar
09.26.2007, 01:03 PM
Actually I'm going to thin everything. My steering isn't as tight as I would like it to be so that should help me there too. I'm thinking 5/10/1 as my f/c/r.
Mike_D
Mike_D's Avatar
09.26.2007, 08:16 PM
I use 7k in the front and rear and 50k in the center. I had good results with a nitro engine so we'll see if it still works fine when i get the brushless stuff in there.
squeeforever
squeeforever's Avatar
09.20.2007, 11:21 PM
The stock Lsp only has grease.
