crazyjr
crazyjr's Avatar
09.20.2007, 11:56 AM
I like to look at it, like camshafts in real engines. As you drop winds its like going up in duration, so while most specs are the same it raises the torque peak a bit. The added winds don't really add torque, if anything the added resistence will drop torque a bit. The reason for more winds, is to move the torque lower and the added wires will help disapate heat
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.20.2007, 02:38 PM
Well, it will increase the 'stall torque' a bit because of the very high currents, of which is basically limited by your power supply (batts).
Actually, the more turns you have, your torque constant goes up proportionally, and you have the same amount of copper in your coils, just a different configuration (higher wind is a longer strand of thinner wire, but the same amount of copper... yada, yada, your torque is determined by your voltage, the copper wind resistance, and the inductance of the winds) for a given motor.
crazyjr
crazyjr's Avatar
09.20.2007, 07:54 PM
by crazyjr
by Zeropointbug
Sorry ZPB, I meant move the torque point, not increase
