09.23.2007, 09:29 AM
Hmm, going by some english specs I found it only weighs about 1.1kg/2.5lbs? If that is anything near correct, then an S can BL motor would be plenty of power.Just match the number of turns to the voltage you plan to use, and aim for about 30-35,000 rpm & 35mph. I could be completely wrong and it turns out to be a tough little bugger. An MM esc would go well with that motor too.
http://www.gems-of-time.co.uk/nitrotek/7.html Specs
speedy
09.23.2007, 02:32 PM
Yes i think that spec are correct ! :) This truck is light ! and wil be even lighter if i get som lipopacks for it :)
