lutach
lutach's Avatar
09.23.2007, 01:52 PM
Originally Posted by tashpop View Post
what esc are you using? i see you hyping it up, but no mention as to what it is. also 7cell a123 wow, thats bigger than your truck.
when i had the issues your having with my 18th, i had to tighten my diffs up. problem is its unloading more power to one side. next problem you'll have is reduced turning ability with tighter diffs, and they seem to strip out quicker when tightened down.
I'm not hyping the ESC. Here are some picture. I might have the diff set up right.
ID:	3265   Click image for larger version
ID:	3266   Click image for larger version
lutach
lutach's Avatar
09.23.2007, 01:53 PM
More pictures.
ID:	3268   Click image for larger version
lutach
lutach's Avatar
09.23.2007, 01:55 PM
Instructions pictures.
ID:	3270   Click image for larger version
ID:	3271   Click image for larger version
lutach
lutach's Avatar
09.23.2007, 01:56 PM
Some more LOL.
ID:	3273   Click image for larger version
lutach
lutach's Avatar
09.23.2007, 02:42 PM
Here are some pictures of the MLST I'll be using to test the ESC.
ID:	3297   Click image for larger version
ID:	3298   Click image for larger version
09.23.2007, 03:01 PM
I will do a write up of how to prevent the internal gears from stripping. I had the same problem and cured it easily. The viscous diffs are the best available for the mlst. All of the others I tried were junk. I have a bunch of mlst diff parts, pm if interested, I will let them go cheap as I have no use for them now. Give me a few hours and I will post up a tutorial on the viscous diffs.
09.23.2007, 04:36 PM
Heres a little how-to on the viscous diffs. The reason the spider gears crap out is because of the o-rings that seal the output shafts. If you take apart the diff you will notice that the output spider gears are keyed to the diff output by means of a small pin, like how a hex is keyed to an drive shaft. The problem is that the thin steel washer that backs the pin is directly on top of the o-ring that seals the fluid in the diff. When the diff spins fast the thin washer is pressed on by the pin. The washer is too thin to stop the pin bending it, and when it folds up it cuts the o ring and lets the output shaft disengage the pin from the output spider gear. My fix was to remove the o-ring and repalce it with steel washers, this also allowed me to shim the spider gears so that they would mesh correctly. Of course this required the use of grease instead of silicone fluid since the diffs were no longer sealed. The washers I used were rc18t wheel washers, linked below. I used 2 per side of the diff to replace the o-rings and it set the mesh tight, but after about 5mins the gears wore in together and I never had a problem again. I used tamiya ceramic grease to lube it up.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJHR8&P=7
