Glitching shouldn't b an issue with 2.4ghz, but here's something you might want to strongly consider: swap the positions of the MM and receiver. Generally you don't want the receiver close to the motor like that, and if it's mounted to the same plate as the motor, then that could be the problem.
OK I found the problem. It’s the servo. Before I start moving everything around I pulled the servo BEC out of the receiver. I replaced it with an extra servo I had laying around. No problem what so ever. Everything works. The servo I pulled out was a Blue Bird BMS-630MG Super Torque. Any issues with these in the past? This is the first time using it so I might have received it bad from the guy I bought it through. Any thoughts???
Sounds like a simple solution to me.... Pitch the POS $18 servo and replace it with a real one and your in business. Bluebird sucks IMO. Never had any luck with them.
to make it...
or break it...
