lutach
lutach's Avatar
09.25.2007, 03:22 PM
Originally Posted by sleebus.jones View Post
Without a set load, those graphs really don't say much about the battery and how it performs. A real discharge graph, discharging at a set load of 10C or 20C would be far more useful in determining the abilities of a battery. You're halfway there, because you already have the datalogging bit of it, you just need a big honkin' load to put across the battery and see how it responds. If you've got the temp attachment, you can use that, and get a temp response graph along with it.
I was going to get a CBA, but I figured that a heavy 1/8 scale buggy would be enough. I have the temp probes for the DPR, but it just add more wires and the batteries only get warm after each run.
