glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.25.2007, 06:14 PM
Yea, even if the battery can drop below 3 volts without any harm at all.... that is not the standard we use to rate lipos.
Also, at such a low voltage performance takes a noticeable hit.
The absolute minimum acceptable would be 3.0 per cell, and we really like to see like 3.2 or so...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
lutach
lutach's Avatar
09.25.2007, 07:50 PM
I'm just doing this to see if what they claim is true. They say the cells can go as low as 2.2V. I'm not doing this to make everyone go out and try it with their lipos. A few other people in other forums are having great results with this new lipos. The 11.1V 2200mAh packs that I have does out perform my 11.1V 4000mAh MaxAmps.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
09.26.2007, 08:41 AM
Agreed. One of the great benefits is the low voltage drop. I woudn't want a pack that drops that low under load, regardless of it's ability to not self-destruct. I'd consider that pack's abilities more of a safety margin in discharging, rather than a higher C rating.
lutach
lutach's Avatar
09.26.2007, 09:10 AM
The point of me doing this is to see how much abuse this packs can take. This packs were not meant for this kind of use. They are being used in helicopters with great succes. In one graph I ran for over 20mins. without an isseu.
