09.27.2007, 11:21 PM
If you do go with the Revo knuckles, I'd try the RPM ones, or an Al setup as the stockers are a little weak from what I've found. Some have no issues, but I was popping the pillow balls out of the stockers left and right until I got RPM.
I know the RPM ones use different bearings than stock, so you might want to check into that before you buy them.
ssspconcepts
ssspconcepts's Avatar
09.28.2007, 12:57 AM
Thanks what about the aluminum Traxxas Revo knuckles? I thought they made some?
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
09.28.2007, 01:10 AM
i just looked at the exploded view for the revo knuckles, and the 2 bearings inside each knuckle are different sizes. the outside is 6x12 and the inside is 12x18. if i'm reading that correctly (don't have a revo) you could get 8x12's for both and it should work... in theory...
Eflite Blade 400 heli on 3s
