Patrick
Patrick's Avatar
09.30.2007, 05:05 AM
Use BrianG's speed calculator for working out gear ratio's. http://www.scriptasylum.com/rc_speed/_top_speed.html
I didn't try to figure out what pinion you need, because I don't know what your using now (or what stock is)
david lamontagn
09.30.2007, 09:59 AM
The only problems with this diff is if i broke the pinion gear or the modify adapter output, it can be a pain to order just this part.
jacobsjo87
09.30.2007, 11:03 PM
Thats true about breaking a pinion, but is there any other option when it comes to putting a stronger diff in a Revo.
crazyjr
crazyjr's Avatar
10.01.2007, 12:31 AM
I have been dumping a Neu 1515/2.5d/f (1700kv) on 5s through a set and they have been holding up fine
david lamontagn
10.01.2007, 03:12 PM
I've make an order of $500.00 + yesterday just in revo and motor parts, so i'll wait this winter to buy a set of this diff. I'll put RD racing aluminium diff cup and just see how long they'll hold, and when i'll break one, i'll put the RCM diff.
Tell me something about Neu motor, which one will be best suit to run on 4s li-po in my revo??
1515 or 1512?? and which wind ? 1Y, 2.5D ... is i'am better to take a smooth or fined can??? don't know anymore about Neu.
Because this winter i want to buy a 16018 MGM controller and upgrade to a better motor. And i'll put the MM controler and feigao 12L in the crt.5
Thank you!
David
