glassdoctor
TEAM FUSION
glassdoctor's Avatar
10.02.2007, 09:37 PM
I've never done this and it's not my idea... but I think you can use a slave motor to spin the rotor (XLT) and measure the voltage across a coil, to somehow figure the kv.
Also, I read you can measure the rpm while it's running using a scope. (or use an actual tachometer) With the voltage into the motor and the rpm measurement, you can calc the kv.
If you can figure the kv.. that would tell you what it is.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Chapito
10.02.2007, 11:14 PM
The first method you listed will work using any of the 10th scale/540 motor dyno's. The problem is finding one with or producing a coupler with 5mm shaft capability on one side. I never did either but came up with a better solution. Sold the XLT4(with disclaimer) on e-bay and forked out the coin for Neu 1515/1y; Problem solved!
