BlackedOutREVO
10.04.2007, 12:50 AM
If you are interested, the GTP shares most of its parts with the ULTRA line of buggies. Diffs, spurs(plastic and steel), arms, etc. It looks just like my MBX R2 buggy, just with a lay down steering servo. I ran my buggy good and it never had a single problem. I also like the solid center spur, great for drifting!
I am interested
Especially in the price! Its so cheap, the darn speedo will cost more then the car, which is not so normal lol... A MM inst far off
So if you were going to give me electronics recommendations
Could you recomend a NEU set up? And a feiago set up all on 4s?
10.04.2007, 12:56 AM
A similar setup that a buggy uses should work. 7-8xl on 4s with a MM. Maybe a 9xl on 5s with a quark 125. Neu 1512(1800-200kv) with a quark125(MM?) on 4-5s. Go HV and buy this and run it on 8s with low gearing, like a 10 tooth pinion!
http://www2.towerhobbies.com/cgi-bin...?&I=LXGCX1&P=7
That might be a bit much, but you could use 2500mah lipos on an 8s setup! Easier to package and possibly lighter?!
