10.04.2007, 10:34 PM
Thanks neil, love that blue blob killing off the red blob, he sure is handy with a pistol!
I only say that cause I have experience with a f103gt. Never had any luck getting mine to track straight, so I sold it. Possibly mount a cut down section of a 2wd nitro trans so that the disk brake sits where the motor usually does and the shaft extends out to allow a pinion gear to be fitted. If the section was small enough a sub sized servo could be mounted on the other bulkhead and it would all be contained inside of the motor pod. It would add some unsprung weight though.
