10.05.2007, 10:59 AM
Sand paper tends to wear off the backing fast, and is not that great on steel, I figured that the grinding wheel material(stoone-like substance) would work the best. As it wears new abrasive is exposed, and it should wear evenly, to keep the shaft diameter the same along its length.
