10.05.2007, 07:12 PM
What about a whet stone used for sharpening knives? If you could clamp down the motor to hold it perfectly still, then use the whet stone pressed lightly against the shaft; since the stone is flat on every surface it will gradually grind down the motor shaft nice & evenly as it spins.
