bluesilver
10.05.2007, 11:04 PM
Ok, This could be my problem.
At the moment I have a Mamba maxx 57000 and controler running on a 8000mah 3s Lipo.
I have it over geared a fair bit. Standard gearing is 24Tpinion and 54T spur. The setup that i have now is 33T pinion and 54T Spur.
All this is in a traxxas Jato.
So from what you are saying is that with this setup The motor is working too hard and heating up the controler?
I should be looking for a larger motor like a Lehner 1930,1940 or a Neu motor?
Is this correct?
david lamontagn
10.05.2007, 11:29 PM
go on BriandG r/c calculation, and with your setup, if you use the jato single speed conversion (i hope you use it) your top speed estimation is about 117 m/h And your motor spin in the 63000 rpm range you'll destroy it !
Don't look for a better controler Just gear it 11/54 and you'll be about 39 m/h.
But, the problem with this gearing, is that you motor will it the tranny case, so the best thing to do is go for a 2s li-po, and your 5700MM motor will take a big breath of fresh air and apreciated alot and will spin in the 40000 rpm range. And you'll can gear it 16/54 and you'll not have problem with your motor hiting the tranny.
