10.06.2007, 07:05 PM
Got the stampede and have looked it over. Installed a MM and ran it with the 9l and 5000 3s pack. It was way slow so I had a look at the pinion, 9 tooth, too small for my tastes. It also had a 49t MGT pinion that was rubbing on the drive cup. I replaced the 49 with a 48t and it clears. I also put a 13t pinion on it for more speed. Went out again and got to the end of the road before the planetary gears in the diff let go. Rebuilt the diff with new internals and lubed everything with synthetic grease. Runs great now, plenty of power and it does about 40mph with that gearing. Batt and esc are keeping cool, good temps on the feigao motor. I will take some detailed pics on the suspension mods, since I know all of you want to see that. I think that I will put my 15l in this on 5s thru a quark 65 and see how it handles the higher voltage.
