Aragon
10.07.2007, 01:48 PM
Kontronik btw doesn't recommend Jazz ESC (without car extension) for car use.
Who said that? I've heard the opposite from Kontronik...
FWIW, I run a Jazz 40-6-18 on 4S in a 1:10 buggy. They work great, and the latest version 8 firmware has fixed one bug I used to experience, and improved the braking/reverse algorithm since version 7.
My BJ4WE has the Jazz setup right now. I was running it in my old RC10 when I posted some results of it. The beauty of the low voltage Jazzes is that they have a builtin switching BEC.
Well I've got a 1:8 conversion in the works, but haven't finished it yet. It's been months since I started it! Hopefully I'll get it finished soon so that I can post my experiences. I plan to run a Jazz 55-10-32 and a Neu 1912/1Y on 10S Lipo in it.
othello
HV basher
10.07.2007, 03:18 PM
Some guy in germany had troubles with a jazz 80-6-18 and Plettenberg Maxximum in a Emaxx. When going from full throttle to say half throttle the motor followed immediately his command: for him it was like braking. While jumping it was troublesome (now he uses a Schulze and does not experience the same behavior).
So he called kontroniks support and their answer was that he was the only one experiencing this behavior and ultimately he should have been using a Jazz car and that they do not recommend other Jazz controllers for car use.
That is the story behind it!!!
Your future 1:8 setup sounds interesting. The Jazz 55-10-32 is a powerfull ESC and is used in helis at up to 4KW (10s and 120A). The 1912 should run very cool. Don't forget to post pictures and comments on this setup. Sounds very promising. Good Luck with your future conversion.
