dadnjesse
10.09.2007, 08:13 AM
I think you should always use thread lock on the set screw!, I use the red and never have a problem. Then to take it off you can heat the set screw with a soldering iron, or I use a small butane torch.
Dafni
Dafni's Avatar
10.09.2007, 08:27 AM
Ask Mike for his Lehner frontbell cover. You'll never have to worry about stripped holes on your Lehners ever again.
Daf
Hakan_J
10.09.2007, 08:32 AM
Daf
That sounds great! Do you have any pictures?
jhautz
jhautz's Avatar
10.09.2007, 08:43 AM
It looks like this.
Works like a charm.
to make it...
or break it...
Silent...But Deadly
Hakan_J
10.09.2007, 08:49 AM
Wow that looks great!
I will definitely ask Mike for a couple of those!
Finnster
KillaHurtz
Finnster's Avatar
10.09.2007, 10:22 AM
You def need a flatspot on the shaft. 5 min w/ the dremmel & its done. I (sometimes) use the blue locktite and a good hex driver and haven't had a setscrew come loose since IDK when.
Hakan_J
10.09.2007, 10:26 AM
But is it safe even with a 4mm shaft? I dont want it to break
