Thread Tools Rating: Thread Rating: 19 votes, 4.37 average. Display Modes
GorillaMaxx360
GorillaMaxx360's Avatar
10.09.2007, 04:59 PM
That much of a small difference... your driving style will have more of an impact than that. It could run cooler, or it could run warmer, I couldn't tell you.
But under the same driver, virtually nothing as far as temp increase. You probably wouldn't feel a difference as far as temps goes.
SO just verifing here just to make sure.
1. so assuming i the same circumstances and same driver with my setup i should experince little to nothing temp difference. (not saying that when i run my car i should expect those temps).
2. the total lower gear ratio does that mean higher or lower temps generally when dealing with the neu motors.
Tags
e-maxx, flm, mgm, neu, ulimited engineering
