Purplefade
10.11.2007, 11:33 PM
Originally Posted by coolhandcountry View Post
I got a concern. Is the savage going to have the room for the 1521 neu in the spot you going to mount it.
It does have limits if you put the motor in some spots. Just like to add that. :)
chc - I too was concerned about that, I know even with my 9XL I was clear against the TVPs to get the mesh correct. I'm still actually a bit concerned with the finned Nue, but seeing so many guys running them, I'm sure I'll work something out. I'm hoping for some more info on jhautz mount, looks like he has his hung off the TVP using a "simple" L mount from say 3/16 - 1/4 inch aluminum. Also liked Serums adjustable mount alot as well, just need to shoot him a quick question on the over all setup and how it worked out. I know he posted his drawings, but I don't imagine I have the skill, nor tooling (more likely) to pull off making one of my own lol...
All that fun said, I've settled on the 1515/2.5d, I think the common theme was that the 1521 was going to be a drive train killer and I do want to have fun with it vs always have it apart for repairs
jhautz
jhautz's Avatar
10.11.2007, 11:44 PM
Good chioce. Thats a great motor.
My motor mount is made up of a 3/16 aluminum plate screwed down from the bottom using the nitro mount holes and then I took 2 of the old Gmaxx motor mount plates and screwed it to the front of the 3/16 plate. I use the nitro motor mount adjustments to set the gear mesh.
You can kinda see it in this picture.
to make it...
or break it...
Silent...But Deadly
Purplefade
10.11.2007, 11:55 PM
Ahh, OK, seeing the bigger picture, I see the bigger picture, lol. When I first looked at it, it looked like you had actually attached the mount to the TVP, I was curious how that worked out. I ended up doing the same thing, I used the FD ring mounts, they go completley around the can holding it like hose clamps (poor discription really, but you get the idea) and attach to the stock nitro motor plate using the stock holes for adjustment as well. All in all I really like them, but with the finned Nue, with any Nue for that matter, I won't be able to continue using them.
Now I have myself curious, maybe I'll look into cutting something down that would let me mount the motor to the TVP, run a simple support brace just over the spur nut and for stability and see what happens. I still like Serums two piece idea, gave him supreme adjustment with out all the headache of flipping the truck around to reach the nuts. Now I'm going to have to get creative!!
I've toyed with the idea of using Mikes motor mount for the Revo and just mounting it directly to the stock nitro motor plate but milling my own holes to allow side to side adjustment. Using low CG TVPs should give me the additional space I'd need for the larger pinions, but the thickness of Mikes mount may chew up a large portion of that as I know his mount is probably 3/16 inch thick or so itself. What to do, what to do
