rootar
rootar's Avatar
10.13.2007, 10:45 AM
the crt.5 is more expensive to build no matter what brushless i use in the ls10, ive seen crt.5 run and i was VERY impressed but the little truck is a little to much for me right now atleast.
10.13.2007, 11:47 AM
You should be able to do the mm/9l combo cheaper the the vxl system.
Get the mm from here: http://www.b-p-p.com/proddetail.php?...Max_Controller
and the 9l from here: http://www.offshoreelectrics.com/pro...?prod=fei-540L
Or you can bid on a 9l that I am selling, it is used but works fine: http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=017
The 9l has a lot more torque than the vxl motor, kv is 2700 vs 3500, but you gear differently to compensate for the slower turning motor. The 6000 3s pack will be fine. You should get at leat 30mins runtime out of it. A good charger is a wise investment, pays off in the long run!
