rschoi_75
Certified Spaceball
rschoi_75's Avatar
10.15.2007, 03:19 PM
Thanks rchippie! I love this thing.
I got some solid testing in this weekend. We got a little break from the rain so I took it to the local park for some street runs and a little baseball diamond action.
Everything surprisingly well! The buggy is quiet and smooth. Mike's motor mount is flawless... as expected. The mesh couldn't be smoother.
It tops out at around 38mph on the street and a little less in grass. It kinda had me wishing for a little more top end, but right now its perfect for a med size 1/8th track, so I think I'm going to stick with the gearing for now. I can always change it later if needed.
Like I said, test went smooth, but I did have a little heart stopper towards the end of the run. I had gotten the street and ballpark runs in as planned and was finishing off the session on the grass. Everything was going great, and I had some real nice rooster tails of loose grass flying around everywhere.
The buggy was so planted I think I got a little too cocky.... I ran it it to about 80 yards away and then saw a splash and water tail coming out.... Now if you've never seen a grown man sprinting across a soccer field with a radio in his hand... its quite a funny sight. Especially if that man is a little out of shape... So I get to the buggy and its soaked. I had accidentally run through a puddle without seeing it. I turned everything off as quickly as possible and immediately went home to dry it off, and try to salvage the electronics. I took all the electronics apart, then proceeded to blow dry the hell out of everything. Luckily nothing was damaged and I was able to put everything back together last night.
Whew... that was a close one. It would've been a world record for "how fast can your kill a r/c car". I think I used up a bit of karma on that one.
Anyways, everything is A-ok now and I can't wait to run it at a track. Its raining again, so I'll just have to wait a few days.
rcm xt8
rcm xb8
rcm crt.5
Hakan_J
10.15.2007, 05:25 PM
That seems kind of low with that gearing? 18/48 is kind of tall? I run 16/46 with a lehner 1940/8 which has almost the same kv and I think that is almost to much for my track!
Nice conversion btw!
